BeniD82
Hi Guys,
Just another question, this time in regard to my Crescendo G3/500 card. I've noticed in the past couple weeks that when I perform benchmarks my CPU performance rating appears to be dropping especially if used for longer periods of time. Hard to explain, but after initial start I usually get a rating of ~1600 in MacBench (this used to be my usual rating), but as I proceed the rating keeps dropping (~1500 to ~1200). I keep checking the temperature which usually idles at 48 - 50 Deg C (about 55 Deg C under heavy load) which is the normal temperature range. What could cause this? I've had this card for years so could it be that the thermal material failing (I think it's using some type of tape rather than paste), but if it did, why is the temperature still reported as the same?
If I have to replace the termal compound, could something like ArcticSilver be used or will it have to be a thermal tape again? I'm kind of iffy about messing with the Crescendo considering how much it has cost back when I purchased it... just wanted to get some input before I do anything to it...
- BeniD82
- BeniD82
