OK, I just did this, and not sure why really. ;-)
Cleaning up my Mac Classic recently, I saw that it has MS Word and Works on it.
Both registered to someone.
So I deleted all the docs, etc..
Then I came across a re-registration program for Word on the Garden, and I ran that to remove the other persons name and replaced it with mine.
Not really sure why.
But it gets sillier... ;-)
I then started to look for something similar for Works 2...
Didn't find, so I went looking for Works 2 disk images.
Found one on the Garden that was preregistered to a fake one word name and organization.
That might.. er.. that screen doesn't look the same...
That is Works 2.00b.. This Classic came with 2.00d!!! ;-)
So, I continued searching....
Finally found images of 2.00d that haven't been installed on Mac GUI.
So I can put this version on the Classic, and remove the other persons name...
And yet, I sit here wondering why I just did that.
I am not likely to really use Word, and less likely to probably use Works...
And did it really matter whose name was there?
And did I REALLY have to make sure it was the same versions??? (Not newer)...
After all this time... Hmmm...
Umm..
Think it's been a long week...
But for some reason, I am glad I did that. ;-)
Umm..
