SE video signal from motherboard to CRT
Under Dog
I'm curious. I've been looking at the SE's motherboard and I see connectors for the SCSI drive, floppy drives, the speaker, and the power connector... but I don't see how video gets off the motherboard to the CRT. Does this happen through one of the wires of the power connector? If so, does anyone have a pin out schematic for that connector?
markyb86
Someone will have a better explanation than I, but video comes from the analog board, which looking from the back is the board on the right hand side.
Blinkenlightz
Exactly - that wiring harness is for both power to the logic board, and video from the logic board to the analog board.
James1095
It's the same arrangement as all of the compact Macs used, at least up until the SE/30 which is the newest one I've poked around in. With the early machines up to the Plus, the power supply and monitor were both integrated into the same PCB.
