Hi. I'd like to get some input from the experts out there. I got a SE/30 showing terminal simasimac symptoms (horizontal zebra stripes). Following the common advice I replaced *all* the caps C1,...,C13 on the motherboard and still get the simasimac. Pursuing further based on the recommendations at I "pulled up" the sound chip UB11, no success, still getting the simasimac. Last, I was going to replace the Bourn filter in RP2 but I'd like to get some feedback as to how likely it is to be the actual fix to the simasimac. The Mac did boot successfully a couple of times (erratically though) since the repair if I left it turned on with the simasimac for a couple of minutes, then turned it off, back on, etc.
Also I did try 2 different ROM SIMMs and cleaned up and reseated the RAM SIMMs, plus cleaned the board with compressed air between each soldering and the battery is only 2 years old, all to no avail.
Anybody experienced this situation or have a suggestion what to try next? Appreciate your help.
