zigzagjoe
So a while back, @Bolle worked on a couple Micron Xceed Macrocolor cards with one or more bad VRAMs. He theorized that it was potentially due to these cards living in very close proximity to the CRT anode, especially when stacked on a maccon or one of his clones.
This seemed like a sound thought process to me, so as I'm looking at stacking cards, I did an unscientific test with my meter's AC setting. Didn't do a good job keeping the meter in view, but you can definitely see that it's getting noticeable noise & apparent voltage fields when the probe is nearer the anode. There's a small change in tone from the CRT, too. Both my machines seem to do this (fully recapped).
My solution was to add a bracket for mechanical support of the card stack as well as to shield for the parts of the board closest to the CRT. There's about 1 cm of clearance between the bracket and the card, enough for airflow.
Has anyone else looked into this kind of thing? I'm curious what other folks do to fit these stacks in & support them, I had to bend the original card supports slightly out of the way and coat them in kapton tape.
