SE/30 Not Recognizing Disks In Internally-Connected Drives
powermax
Would you kindly describe (again) as detailed as possible what happens when you insert a disk in the internal drive?
Turaiel
When I insert a disk in the internal drive, regardless of the type of drive and type of disk, the OS tells me the disk is unreadable and prompts me to format it. The disk and one of the drives is known to be good and works fine in my other Mac SE.
powermax
What happens when you tell the Finder to format the disk? Does the formatting work?
Turaiel
I don't remember what happens if I try to format it. I'll check this week once I get the machine reassembled. Right now I've got it torn apart to check those traces and joints.
powermax
When you own another Mac SE you could try to compare the resistance of each FDD connector pin to the ground between the good and the faulty boards.
If you multimeter has a diode test mode: red probe on ground, black probe on each pin of the FDD connector joints. Otherwise, test in resistance mode.
If there is a problem in the logic board's the circuitry you'll get a notable difference...
techknight
That will only tell you so much, of actually very little.
Only thing that is good for is finding huge discrepancies and/or direct shorts.
Problem is, the semiconductors are never the same from chip to chip, transistor to transistor. There are manufacturing variances, die variances, etc.
Thats why one transistor might read .561 but the next one reads .512 and another one reads .608 But they are all 2N3904s from the same batch.
This is a small trap to look out for.
powermax
I agree with you that this kind of measure is very coarse. Anyway, it's one of those quick troubleshooting techniques helping to rule out reasonably simple issues like missing contacts or shorted traces. Any other issues would require attaching an oscilloscope to the board and do a complex logic analysis in order to identify failing circuitry components. That's clearly beyond the skills of the average DIY Macintosh hobbyist...
powermax
I'd also check the voltages on the drive board for sure, both +5V and +12V rails. It should be definitely done under load, i.e. the drive need to be connected to the logic board.
For pin position and numbering, you can refer to this page.
+5V rail -- pin 11
+12V rail -- pins 13,15,17 and 19
GND -- pins 1,3,5 and 7
Turaiel
I resoldered the floppy header, but it seem to no avail. It still is unable to recognize disks. I did try to format an 800k disk I had lying around, and it said it was unable to initialize it.
As for the above pinout, I'm afraid I'm not sure which diagram you're referring to.
powermax
I know this might be a stupid question but I assume you're connecting your drive to the both machines using the same ribbon cable. It works on one but not the other, right?
Turaiel
I'll check the link, thanks.
I've tried both ribbon cables. They work in the SE, but not the SE/30 (the one with the issues).
Turaiel
I just got a chance to check the voltages here. On both my SE/30 (issues) and SE (known good), pins 13, 15, 17, and 19 are measuring around -12V with pin 11 measuring between -7 and -7.6. You mentioned they should be +12 and +5, so the reversed polarity seems a bit weird to me.
techknight
13, 15, 17, 19 are all +12V
9, 11 is 5V
Not sure how your getting negative voltages unless you have your meter wired wrong.
Turaiel
The voltages are definitely reading negative, unless for some reason the red probe is supposed to go on the ground pins. Pin 9 is measuring around -7.5V. Something of note: pin 11, which was reading -7ish V yesterday is now 0V (on both machines). The machine which was previously working can no longer read disks. The SE/30 also powered off unexpectedly while I was testing and refused to turn back on until I removed the power from the PSU for a few seconds.
Turaiel
As an update, neither floppy drive on my SE/30 is functioning now, including the external. The external now will not even power on. On top of that, I now get a "bus error" when I try to shut down the machine. The restart button on the dialog just causes it to do the same thing, and the interrupt button on the programmer's key just cases an "unserviceable interrupt" error.
These symptoms were not present prior to my voltage testing. I hope I didn't fry anything...
Turaiel
More update: with some assistance I've identified that the voltages across capacitors C8 and C9 are inverted. The PSU is outputting healthy voltages as far as I can tell (though the -12V line is running at about -10V). Any ideas?
Turaiel
Hello again,
It's been a while since I updated this thread. I've decided to pick up this project again but I'm still stuck in the same place I was in September. That is, the machine bombs if I try to shut down, restart, or press the interrupt button. No floppy port is functioning either, including external. It's possible that back when I was testing voltages out of the floppy connector, I touched the data and power leads together with my probe. Is my SWIM perhaps damaged, and more importantly, is this recoverable? Also, any ideas on the wrong voltages appearing on the board?
At this point I've put so much time and money into reviving the machine that I don't want to give up on it, but the issues may have exceeded my skill level at this point.
Thanks.
