You have a broken trace to the ROM SIMM.
More rarely, you could have a shorted data buss from solder falling through the vias and smearing to the adjacent vias, and it will do the same thing. You will need to flip the board over and inspect all the areas where the caps are and make sure there are no crossed-over solder. This occurs in the sections your heating up and reworking to replace caps or chips. If you used a heatgun, this happens.
Once you have an eagle-eye for that, youll see it quickly. If that fails, you can meter all the A and D lines against each other for shorts. If that checks ok, then you definitely have a broken ROM trace. you COULD have a bad CPU, but thats really really rare. I have seen it once though with someone elses board, What gave it away was when scoping the bus with the ROM simm inserted, all the Data lines dropped down in voltage to around 2.5v or so which i knew then the CPU was toast.
