Hi all,
I have a SCSI multi-card reader that I originally bought to use with an Emax sampler. That never happened, so I thought I'd try to get it running with my Quadras:
I'm close to getting it working, but I can't get a disk to mount. This is what SCSI probe says:
As you can see, it can recognize all of the slots, and it can even flash the LED, but it can't mount the disk. When I try it says "Not a Macintosh Volume". I tried formatting the card as HFS using MacDrive on Windows, but the results are the same. The SD card reader is on LUN 3, is this the problem? Do I need a PCMCIA to SD converter to put the card on LUN 0?
Has anyone ever got this to work? BTW, I get exactly the same results using the Quadra 650 and the Quadra 700. Both run System 7.6.
Thanks,
Daniel
Thanks,
Daniel
