SCSI2SD Universal Mount
ants
Trash80toHP_Mini - designing a mount that doesn't require disassembling most of the SE/30 to remove the drive would be great. I'm just waiting for the day that I break something or fry a board due to my stupidity.
And yeah in hindsight I probably should have drilled larger pilot holes for the screws I was using - as there was a risk I could have broken the mount with the pressure I was applying. Alternatively, getting shorter screws would have been safer - perhaps around 5mm.
aperezbios
wow looks great,,, any chance for SCS2SD v4 mount?
That seems very unlikely, unless you do it yourself, as V4 boards have not been manufactured in nearly three years. The percentage of all SCSI2SD devices out there which are V4 is _very_ small, I'd wager less than 1%, at this point.
CC_333
Then I must be very unique, since I have several V3 boards sitting in my closet.
I remember when V1 came out, it wasn't that long ago. 2014? 2015??? Somewhere in that range, I think.
c
Byrd
Hi Joe,
Just a quick note to say thanks for making up this mount - I've just printed it out for a Quadra drive sled, using a SCSI2SD v6.  It fits and works perfectly.
JB
