dcr
Has anyone mounted a used (meaning it didn't come with all the parts a new machine would) G5 Xserve in a server rack?
From what I read, you take the cover and mount that to the server rack and then slide the Xserve into the cover. Sounds easy.
The screws I had for the server rack (which work for the front panel) were too large for the screw holes in the back of the Xserve cover. I looked up the right size and ordered them. After the experience with Amazon, I finally received the screws. I took the cover off the first G5 Xserve and mounted it on the front of the server rack. Easy. But, the server rack was too long in the back, despite my measuring it when I assembled it. Fortunately, it's a half-size server rack so I was able to unscrew the back end of the server rack, slide it in smaller and get it to the right size.
Then I go to mount the rear of the Xserve. But it is too far away from the mounting holes on the server rack. And the screws are too short. And the screw holes do not seem to line up with the mounting holes on the server rack no matter how I adjust it.
I can only assume I am either missing something or doing something way wrong. Does anyone have a G5 Xserve mounted in a server rack? If so, can you share a photo of how the rear of the cover is mounted? Searching online, I've only found images of the front and nothing showing the back.
