iamdigitalman
Hey all. My new pet project is getting my workgrkroup server 8550/132 set up as a server. Not sure what I want it to do yet, probably hook up the color stylewriter 2500 and have it be another printer for all the machines in my house, or as a file server for part of my files. I will figure that out later.
Anywho, I was looking over the system requirements for Mac OS X Server 1.0, and did not see my machine on the list (though I did see the beige G3, one of which I happen to have in begging to be a server tower form). So, I stepped things back to Rhapsody DR2, since I have a copy, plus it's basically unix, and I can run some server software off of it.
I popped in the CD, and it refused to boot, instead of booting the CD, it booted 7.6. I opened the case up, and switched the SCSI ID, and it booted right off the CD. After installing in the Mac OS, it rebooted into the rhapsody installer, and it sat there and installed for a bit. It requested a reboot, and I told it too. Upon reboot, it died. I got the power light, and the fans, and the HD was spinning, but the monitor never came out of standby, and I could not hear the HD reading.
Frantic, I rebooted and pressed C. Surprisingly, it booted to the Mac OS install on the rhapsody CD. The install is now hosed I think...
What gives? Isn't the 8550 just a modified PM 8500? There is a G3 upgrade in this beast, but from what I have read, it should still work and show up as a fast 603. I do have the original 604 card I think, in the newpower G3 box, I could swap that back in.
Specs:
Workgroup Server 8550/132
G3 of unknown speed
224 mb RAM
17gb SCSI HD
Apple Fast Ethernet PCI card
Would this machine also work with MOSXS 1.0+? If so, I would like to make it work. Ideally, I would like it to run 1.2v3, but I can't find a copy, only 1.0 and 1.1.
-digital
Specs:
G3 of unknown speed
224 mb RAM
17gb SCSI HD
-digital
