Recommendations for SCSI disk recovery software
jdlanza
I have a number of old SCSI drives that I would like to try to revive, if only to capture the apps before trashing the drives for good. Anyone have recommendations for good tools to use? Thanks!
mmu_man
Not SCSI specific, but it should work, GNU ddrescue can make an image by doing several passes, skipping bad blocks first, then scrubbing them to get the most of them. Works on Linux, probably also on OSX.
Once you have a raw image you can convert to dmg or whatever and work from that with tools to check the filesystem (sadly TestDisk doesn't know about HFS), or copy files.
