Mighty Jabba
I bought a 1400c for a pretty good price, but when it arrived I found that it gave me a message saying, "The built-in memory test has detected a problem. Please contact a service technician for assistance." It would boot up okay after that, but would only recognize 56MB instead of the 64MB that was installed. After a little troubleshooting I was able to narrow it down to one of the memory expansion boards, since the message went away when I removed it. I also found that it would occasionally recognize all 64MB, but then it would start giving some odd errors during use. I think the intermittent nature of the fault is why the seller didn't mention it, but I got a partial refund because of it, making my final cost about $30 plus shipping. Anyway, I was wondering if I was better off just removing the offending board and only running with 40MB, or if things should work okay with 56MB when that error is displayed. An extra 16MB of RAM would be nice.
I also got a Nupowr 183MHz PPC upgrade for the 1400, so I decided to try installing that. At first I didn't realize that it required software, since I only received the board itself, and it seemed that the system was only recognizing it as running at 100MHz. My improvised speed tests in Photoshop seemed to bear this out, since it was about 20% or so slower than the stock configuration. But once I installed all of the software for it from Newer Technology's site (and props to them for still having these available BTW), it worked fine and gives a modest speed boost.
While I was working inside the computer, I noticed that I seem to have an additional board in mine that I haven't seen in other photos, and I was wondering if anyone knew what it was (in the middle).
