Fizzbinn
I’ve previously used a 3 AAA battery holder to replace the dead Rayovac 4.5v “Computer Clock Battery” in a couple of my Macs.
After some chat discussions I thought I’d try something different for my Performa 575, especially after noticing that in the Macintosh LC 520/550/575 Service Source doc it notes that 575 battery is good if it’s 3 volts or higher, the same as it says for the 520 & 550 which use 1/2 AA 3.6v batteries…
So why not try a CR2032!
I though of cannibalizing a @Geekybit MeowToast 1/2 AA battery Replacement (which are awesome) but found another holder on Amazon so I can keep those for Macs with the 1/2 AA holder.
AuBreey 5PCS/LOT for Arduino Lilypad Coin Cell Battery Holder CR2032 Battery Mount Module:
Cracked open the Rayovac mainly since I was curious:
Soldered the cable from the old battery to the new holder:
Reused the velco from the old battery too (still had stickum):
575 board with 3 AAA based battery holder:
575 board with CR2032 based battery holder:
Close up pic, perhaps most importantly it works just fine!
Amazon.com: AuBreey 5PCS/LOT for Arduino Lilypad Coin Cell Battery Holder CR2032 Battery Mount Module : Electronics
www.amazon.com
