Quicktime being stupid on Pismo
MultiFinder
Okay, so as you may know, I've upgraded this bugger a bit. Here's its specs now:
G3/500, 512 megs RAM, 30 gig HDD, OS X 10.4.11
It's a very happy machine, except for one thing; it won't play quicktime movies. When Tiger installed, it played the intro movie fine without any hiccups, so I *know* it can play them, but it won't. All it does is bring up a blank QT window and play the sound (if there is any) and nothing else. Here's a picture of it (not) playing the intro video:
http://img530.imageshack.us/my.php?image=picture1ty4.png
Any ideas what's making it do this? It's really rather annoying, especially since I *know* it can play them fine, as it did when the bugger first booted. Thanks!
Christopher
the reason the intro played well is because of what the encoding is. I have installed tiger on a 300MHz mac and the ntro bid plays well. If you can figure out the encoded format let me know. I have DVD movies play without hiccups. Can someone tell me if the dvd's format is acheveable?
wally
...Any ideas what's making it do this?...
You can look in your user library folder for the Quicktime preferences file(s). Perhaps there is an out of date duplicate or corrupt copy, and purging them forcing Quicktime to create a new file might help. Failing this, a disk diagnostic followed by a reinstall of Quicktime might be a reasonable next step.
coius
Try using VLC instead? :p
I second John8520's idea! I use VLC for everything from flash, to DVD and it plays them great!.
I just got a more recent problem that either quicktime plays only the video, or VLC only plays the sound. I can't get either of them to play both the video and the sound :(
Temetka
I use quicktime for 99% of my needs.
When coupled with perian it is quite versatile.
Oh and I paid for QT Pro if that makes a difference.
I do use VLC, but only when QT fails me; which is rare in the extreme.
wally
I'm thinking the problem is Quicktime plugin being stupid under Safari...
My Pismo
10.3.9
400 MHz PowerPC G3
256 MB SDRAM
Trying to play your movie on your problem, by viewing your post from the following browsers and clicking on your link:
Safari 1.3.2 plays sound only
Firefox 2.0.0.16 plays ok
Camino 1.6.4 plays ok
So then I go back to Safari and do a copy link from your post. I open Quicktime and paste the link into open url...and Quicktime plays it ok!
Go figure...
MultiFinder
Wow, you're having the exact opposite issue from what I'm having; bloody QuickTime, make up your mind what you want to break :p
wally
Now I can't save as QT movie and then try to open it like you did because the QT plugin under all three browsers asks me to pay for QT Pro upgrade, but I did try all three browsers with the link extracted from your movie screen,
http://pulsar.esm.psu.edu/Faculty/Gray/graphics/movies/g4_tanks_LAN
(pasted to each browser's location bar)
Safari: plays only the sound
FireFox: plays ok
Camino: plays ok
Then, I ask for the info on the QT player plugin, and in all three browsers it is the same, version 7.5. Well, they sure do not work the same.
And I tried Quicktime itself going to the above URL without any browser, and QT plays the movie ok directly (but again, wants me to buy an upgrade before allowing me to save).
