Hi all - does the DiimoCache 50mhz work with System 6 on a machine which would otherwise support the OS? Or does it, as indicated here, require System 7.0?
Grateful for swift replies as I'm considering blowing a large bucket of money.
Also, I realised I put this in the Compact Macs channel, which made sense at the time because I want to put it in an SE/30, but it might not be the best place. Sorry.
I don't see anything about compatibility with System 6 anywhere. I see no minimum requirements, just that it's compatible with 7.0, 7.1 & 7.5. Besides, for System 6.0.8 on an SE/30, who the heck needs an accelerator and for what? :huh:
The photo of Knez's box in my second post says 6.0.5 is the minimum, but then that's only under the LCIII and Performa 450 line, which can't run system 6 anyway. Hmmmm.
Are you really gonna use either of them for much and for what? It all boils down to the applications you need/wand to run for what you choose to do with any computer.
You'd get better bang for the buck by accelerating the TAM because you can do more A/V kinda things with it. The SE/30 everyone seems to love, but I can't figure out what they do with them other than pimp them out. Almost any desktop at its Mac IIcx level is much better at every single thing the SE/30 can do aside from fitting into a cute little Compact Mac Bag.
At least the TAM is a fairly good Stereo and pretty too if you like that sort of thing.
"Because it's there" is all the reason I ever need to take a whack at doing something inadvisable. [}]
I took my SE/30 to Switzerland for a summer internship in one of those bags as carry on back in the day. I liked it because it was a working Mac with a small footprint that I could later improve with an external monitor when I could afford it.
i think people like them so much because the compact Mac is the iconic humble origin of the Mac line and the SE/30 is the king of that form factor. I’ll use my pimped out SE/30 the same as I would any other vintage Mac.
