kissmyash933
Hey all!
I recently acquired a Duo 2300c with a dock, microdock, floppy drive, and a SuperMac NuBus video card inside the DuoDock II. I also acquired a 230 from an eBay auction.
I have a few questions about these units.
My 2300c has 20 megs of ram in it, yet somehow feels slower than the 230 with 12 megs of ram. The 2300 came to me running OS 8.1, and the 230 had 7.1, but I put 7.6 on it, and it's up and running beautifully. I'm thinking that maybe because 8.1 still has a lot of 68k code in it that maybe if I upgraded to 8.5/8.6 that it may fare a little better? thoughts?
Secondly, my 2300c does not run off of a battery AT ALL. this computer will run fine in the duodock and off the power adapter, but once i try to put it on a battery, it doesn't make an attempt to start or even run at all. I heard somewhere that there could be a fuse bad in this computer? I've aligned the contacts on both computers and the 230 runs great off of both batteries. Any suggestions here?
Also, Where can I find OpenTransport for the 230 so that when it's in the dock I can access my server with it's IP address? Hotline mayhaps?
I'm currently running ExtremeZ-IP to access my PC, because when I try to connect to my OS X server with 8.1 it tells me: "the login type is not recognized" or something along those lines. any way to fix that in 10.5 Server?
I took the SuperMac card out of the Dock, because when it was running, it would make my monitor all funny, wavy and weird. I think the card is labeled Spectrum or something, but I know that it's a full length monster and the copyright date on it is from '88. any way of fixing the crazy monitor issue on it? I'm not sure if it needs drivers or if it's just such an old card that it doesn't work properly anymore.
How would I go about reconditioning both batteries? One of them is an actual Duo Type III, and another is a BTI type 4. If I try to run Battery Recondition off the 230, it tells me that It isn't compatible with this computer.
I've looked around and found that there are some updates for the Duo series, what updates are required for what computer?
Lastly, The drive in my 230 is clicking, where can I go about finding a SCSI drive on the cheap, or at least something that will convert an IDE drive into a SCSI drive.
I'd like to have both of these computers running flawlessly, because I enjoy using both of them!
Thanks in advance for all of your help! I'm sure that once I get these up and running, I'll be back around here much more often! I haven't used a 68k mac, or any mac running less than 10.3 for years!
Thanks so much!
Blake.
Thanks so much!
Blake.
