croissantking
So while restoring my 840AV, I’ve found that the PSU is dead or at least nearly dead. It’s a Delta SMP-220DB. The symptoms are that it will click on, then click off again. Sometimes, it stays on a bit longer, but it seems to be struggling from the way the fan sounds.
It does the same with two different Quadra boards, so it does point to an issue with the PSU itself.
Has anyone attempted to recap one of these?
