Quadra 630 RAM
Status
Not open for further replies.
LCGuy
LC Doctor/Hot Rodder
They use 72 pin SIMMs...pretty easy to find, and cheap. Commonly found in later 486 and early Pentium PCs, as well as the following Macs:
LCIII/Performa 450
LC475/Performa 475/476/477/Quadra 605
LC/Performa 520
Performa 550
LC/Performa 575, 576, 577, 578
LC/Performa 580, 588
Mac TV
Quadra/Centris 610
Quadra/Centris 650
Quadra 800
Quadra 840AV
Power Mac x100
Power Mac/Performa 5xxx/6xxx (apart from 5400, 5500, 6360, 6400, 6500)
MacMan
There is only one SIMM slot in the 630 so try to get a 32MB or 64MB 72-pin SIMM. They are available cheaply these days and the easiest place to find them is eBay.
From the sounds of your other post there is already a 4MB SIMM in there so it'll need to be removed before you install anything bigger. There is also 4MB built into the motherboard.
Bunsen
Admin-Witchfinder-General
If you're buying from ebay make sure you get FPM (fast page) or EDO RAM and not ECC RAM.
trag
I don't know if the Q630 will go that high, but 128MB FPM 72 pin SIMMs are also available. IIRC, look for HP D4893A, or D4290A for 64 MB.
The D4893A works as 128 MB in my Q605.
Status
