PowerPC 601 Upgrade Card Software
macuserman
Ok so I’ve been trying to test some apple branded PowerPC 601 cards in my Quadra 700. So far not much luck with the software. I have tried using this software from the garden https://macintoshgarden.org/apps/apple-power-macintosh-upgrade-card-installer-m2843lla
But partway through the install it asks me to swap in a “goodies” disk, which doesn’t seem to be part of the uploaded software.
What am I missing here? Is there better software I should use?
Yeah, it's on all System disks in the 7.5.3 to 8.1 era. Just install it from an OS disk.
macuserman
Hmm ok guess I need to find a good disk then. Not sure if I have any retail disks in that range have a bunch of specialized system specific stuff not sure if it would work from those.
ktkm
Did you solve it? I have the same issue with a Quadra 950, the install asks for a “goodies” disk. I tried with a clean 7.1.2 install as well, but it doesn’t want to boot in PPC-mode and complains the HD is an unsupported disk.
ktkm
@macuserman I got it working with a “Goodies” disk from the 7.1.2 US version. I also learned that the “Power Macintosh Card” uses a different enabler with System 7.1.2, which is why my clean 7.1.2 install didn’t work.
