Powerbook 5300cs CF card boot
somorastik
Hello, Mac Liberators!
Im running into a lot of problems trying to boot my Powerbook 5300cs from a CF card.
I tried PCMCIA adapter and a CF->IDE adapter. Three different kards (Kodak 256MB, SanDisk 1GB, and some 4GB card from my DSLR)
None boot with the adapters I have.
http://www.ebay.co.uk/itm/PCMCIA-Compact-Flash-CF-Card-Adaptor-for-Laptop-/320646084730?pt=UK_AudioTVElectronics_PDAsAccessories_MemoryCards&hash=item4aa7fef87a
http://www.ebay.co.uk/itm/Dual-CF-Compact-Flash-to-44-pin-IDE-2-5-Male-Adapter-/200492046409?pt=UK_Computing_Drive_Cables_Adapters&hash=item2eae41d849
I want to boot from the CF, not the old hard drive (which is dead).
Do you have some verified adapters/cards?
Could it be that the firmware of the powerbook is not up dated, or something like that?
Please help.
Thanks
Bunsen
Admin-Witchfinder-General
The dual-slot CF to IDE adapters are not recommended. The Mac is not capable of reading both slots. In general, the simplest, straight pin to pin single slot adapter you can find is best.
From my reading here, it is important to make sure that your CF cards are capable of "true IDE" mode, aka - UDMA
somorastik
Thanks bunsen for reply.
I finaly figured it out.
The two slot card reader does work, probably only for one card, I havent tried two. As the mac disk controller cant mount two disks as far as I know.
The key to have it working is to format the drive, Mac Os standard for System 7 and Mac Os Extended for System 8.1.
Now I cant get my fingers on the system 8.6 in Czech localization. I have some CD but they seem to be broken, as the install allways dies half the way. System 7.5 installed no problem.
