PowerBook 500 Series full 040 CPU swap
Durosity
You definitely should!
I’m guessing this mod could be applied to the 190 and the Duo 280c.
I was thinking that too.. actually I’m thinking if you took a 190 and replaced its screen with an active one from a 5300 (maybe even a CE?) and gave it a full 68040 you’d pretty much have the best portable 68k machine!
CC_333
The best portable 68k machine, in my mind, would probably be one whose plastics aren't crumbling and whose hinges (if a laptop) haven't failed.
Does such a model exist? I don't know. I sort of doubt it....
c
croissantking
I sourced another of these CPUs, this time a Freescale MC68040FE33A, L88M mask. It’s on a donor board so is likely to be genuine. I think it should work - stay tuned for more surgery.
Durosity
c
Oh indeed.. I think the plastic on every PowerBook ever made is starting to crumble now, especially the ones made around that time.
3lectr1cPPC
PowerBook 100’s plastics are still holding strong (about the only part of that thing that is)
Plastics aging are just a part of old laptops. Coming from someone who collects a lot of PC laptops I’ll just say one thing - be glad that you can reliably fix the hinges on these with a bit of work and 3D printing. Compared to how bad hinge failures can get on some PCs, the PowerBook 500 can look like it deserves a build quality award.
