Is it possible to run .jar java programs in LC 630? It has the System 7.5.5. OS installed. Or are there any double-window filemanagers for 68k Macs? (Norton commander look-a-like).
It’s probably Java 1.1 though so it might be too old for you. But it should work on 7.5. Newer MRJ versions required System 8 I think. It’s been a while...
Yes it is probably not possible to run .jar files in classic mac. I installed Netscape 3.0 and it run local html files with java but not .jar files. The same with IE 4.01 full version. There is OpenDoc stationery that i suppose should run java applets but it says "applet loading..." and nothing happens.
