AichEss
As I continue to unpack a 3400c/Kanga stash stuff comes up that I don’t remember from when it all was put away.
Comes now a 3400c with a startup issue. It chimes, the HD spins up, it takes some time to check the RAM and the LCD backlight comes on - and that’s it. No Happy Mac, no HD reading sounds, nothing else. When I do the startup with a CD in the drive, the same routine; chime, the CD spins up and the activity light sometimes flickers early (as in to find if the drive is occupied) but no Happy Mac and not the first reading sound.
There are no beeps during the startup sequence. The 4-key PRAM Zap works as it should but doesn't make any difference, the cursor moves with the trackpad just fine, holding down the power key doesn’t produce a shutdown.
Are there any tricks to reestablish the startup sequence so it will go all the way?
Thanks
Thanks
