Overclocked QuickSilver
slomacuser
I bought a 933MHz QuickSilver from a friend that I tought is 2002 version. What I found out is that is a 733MHz 2001 version overclocked. So I made a resaarch and found this site http://powermac-g4.com/g4quicksilverclockup.html
well mine is overclocked from 733 to 933, for now works ok, running Tiger and Leopard and scores from 23 - 26 points on XBench http://www.xbench.com/.
picture of mine overclocked processor card http://shrani.si/f/Z/VB/mNCcrzs/-1.jpg
Anybody else with overclocked QuickSilver here? I can not check the heat as there are no temp. sensors on this machines.
Rodus
That's a pretty good overclock, those G4's run fairly warm, something that may not be apparent if you haven't really pushed the machine. It would probably be worth removing the heat sink and applying some good quality thermal paste and (if you have space) stick in a PCI slot fan for some extra cooling.
Christopher
The QS had some wonky cooling that was loads better then the graphite models so, maybe the cooling system will work fine.
kissmyash933
can anybody else with quicksilver make a xbench test?
Slomac, I ran a test on my Quicksilver. Here are the results:
Code:
Results	46.23
System Info
	Xbench Version		1.3
	System Version		10.5.5 (9F33)
	Physical RAM		1536 MB
	Model		PowerMac3,5
	Processor		PowerPC G4x2 @ 1.00 GHz
		Version		7455 (Apollo) v3.3
		L1 Cache		32K (instruction), 32K (data)
		L2 Cache		256K @ 1.00 GHz
		L3 Cache		2048K @ 250 MHz
		Bus Frequency		134 MHz
	Video Card		GeForce2 MX
	Drive Type		ST3200820A ST3200820A
CPU Test	53.76
	GCD Loop	95.00	5.01 Mops/sec
	Floating Point Basic	34.31	815.26 Mflop/sec
	AltiVec Basic	197.83	7.88 Gflop/sec
	vecLib FFT	59.38	1.96 Gflop/sec
	Floating Point Library	31.82	5.54 Mops/sec
Thread Test	58.25
	Computation	85.22	1.73 Mops/sec, 4 threads
	Lock Contention	44.24	1.90 Mlocks/sec, 4 threads
Memory Test	37.71
	System	44.12
		Allocate	155.34	570.46 Kalloc/sec
		Fill	41.99	2041.76 MB/sec
		Copy	26.50	547.28 MB/sec
	Stream	32.92
		Copy	34.58	714.21 MB/sec [altivec]
		Scale	35.16	726.40 MB/sec [altivec]
		Add	31.72	675.67 MB/sec [altivec]
		Triad	30.65	655.73 MB/sec [altivec]
Quartz Graphics Test	60.47
	Line	51.65	3.44 Klines/sec [50% alpha]
	Rectangle	55.42	16.55 Krects/sec [50% alpha]
	Circle	48.27	3.93 Kcircles/sec [50% alpha]
	Bezier	56.42	1.42 Kbeziers/sec [50% alpha]
	Text	146.12	9.14 Kchars/sec
OpenGL Graphics Test	65.26
	Spinning Squares	65.26	82.79 frames/sec
User Interface Test	28.52
	Elements	28.52	130.89 refresh/sec
Disk Test	45.03
	Sequential	79.99
		Uncached Write	62.60	38.43 MB/sec [4K blocks]
		Uncached Write	93.96	53.16 MB/sec [256K blocks]
		Uncached Read	71.09	20.81 MB/sec [4K blocks]
		Uncached Read	107.27	53.91 MB/sec [256K blocks]
	Random	31.33
		Uncached Write	10.70	1.13 MB/sec [4K blocks]
		Uncached Write	65.22	20.88 MB/sec [256K blocks]
		Uncached Read	90.26	0.64 MB/sec [4K blocks]
		Uncached Read	128.88	23.91 MB/sec [256K blocks]
Hope that helps.
Blake.
