supernova777
i have a mac radeon 9200 mac edition PCI in my B+W g3 450mhz right now (which is running os8.6)
it works geat... nice + fast.. but i have had alot of issues getting the right version of the drivers + getting them installed properly on os8.6
right now my accell isnt working, and as far as i can remember atm, im not sure the 9200 will ever work properly in 8.6 - some say it was only everupdated to work with 9.22
thats why if theres a cut off point and the 9200 is after it.. then the 7000/7500 must be before it? its annoying - they documented it well but not well enough.. they made these
"one size fits all" driver packages when i wish they jsut made a seperate drive rinstaller for os8.6 and one for 9.22
i just want my accelleration working properly if i have to use a rage128 or XlcaimVR 128 or use the stock RagePro128 to do so then i guess i have to live with that
or i could use a 9800 pro or 9200 and just "get used to it" re: the rollup effect when dragging windows........ those cards are pretty fast even without proper 2d accell + support
but if it glitches out when scrolling or draggin and uare doing alof then it can drive u nuts
