vexatious
Sawtooth G4 AGP
MDD dual 867Mhz
Powerbook Ti DVI (mobility 7000)
Anyone try a PC Radeon 9100 PCI with MacOS 8-9-rhapsody?
Radeon 9100 PCI for pc is essentially a Radeon 8500 on PCI and slightly lower frequency. It's uncommon and somewhat unpopular. https://www.techpowerup.com/gpu-specs/radeon-9100-pci.c805https://www.techpowerup.com/gpu-specs/radeon-9100-pci.c805. I hope the ATI MacOS 8-9 system extensions work transparently...
Is there a way to override the primary display card through open firmware or other means? E.g. if I have a Rage 128 AGP & Rage 128 PCI, how do I truncate the AGP and startup MacOS 8-9-rhapsody with the PCI card? I know this works on Linux by editing xorg.conf, but not sure about open firmware and/or MacOS...
Thanks
MDD dual 867Mhz
Thanks
