Sonnet Clocker II: software extension overclock of Sonnet L2/Nubus G3 accelerators
Byrd
Hi,
Reporting on a little discussed utility that I'd forgotten about ...
http://www.zone6400.com/Sonnet_Clocker.html
Sonnet Clocker (use the rev. 1.2 version) is a utility that edits the Sonnet G3 extension to adjust the multiplier of a L2 or Nubus based Sonnet branded G3 accelerator.  I'd never heard of successful software overclocking on Mac hardware, but can confirm I can overclock a Sonnet G3 400Mhz (1MB cache) L2 accelerator in my TAM to 500Mhz, as confirmed in benchmarks.  Running at 500Mhz, it gets hot and I have replaced thermal grease on the card and intend to install a small fan nearby to dissipate some heat from the cramped TAM internals.  Of note, it did not work at 450Mhz, I believe G3 revision and multiplier support is the key here.
Next I'll try it on a Sonnet Nubus G3 300Mhz card.  Results may vary for you and on particular hardware.
JB
Byrd
No - multiplier speeds only.  If edits the extension which you have to remove the old, and drag the edited one back into the Extensions folder.
trag
Okay, I"ve since dug through the PPC750 datasheets and the L2 cache multiplier/divider is set in software.   I wonder if this utility can be hacked to adjust other parameters.  So the utility adjusts just the CPU bus multiplier, correct?    That's a different parameter from the one that would adjust the cache multiplier, and cache size, unfortunately.
