Glad to see this thread reappear! I've been playing with two 400/512K L2s in a 6500 and what I'm hoping is my 6400 board. I'm also hoping it's just a corrupted driver as both machines boot fine with either card installed, but the driver shows up as disabled.
I'll have to try thermal compound, but that wouldn't be an issue until cards warm up a bit would it?
Don't recall info on paste being the culprit at boot, IIRC it's associated with erratic behavior under use? That's what has me confused here, I'd think it would stay cool enough to pass POST and the boot process before wigging out? Does the accelerator shut itself down to avoid damage when it exceeds safe operating temperature? Wondering if I might have cooked both cards during testing?
From the box and spec, pretty sure I picked these particular cards up as NOS from Sonnet when they cleared out accelerators. Hoping to find the 6360 board with the original Crescendo ???/1MB L2 in working condition.
edit: Oopsie, forgot to mention I'm running with/without a dead PRAM bat. Gotta build a couple or three, Does it really matter so long as the machine stays plugged in, other architecture seem to retain PRAM setting in that state?
I'd feel sorry for the TAM gang because you don't have room for a battery holder, but if you've got the money to be messing around with a TAM, those batteries don't seem all that expensive.
One more! Both my boards booted right up with chimes a time or two, then sound died entirely. Is that "normal" behavior for a board that needs a recap? I have cans on my 6500, did Apple use leak-free caps on the TAM boards or are you folks recapping? There's a can right next to (for?) the Cache slot. Could this be the culprit? Low voltage/instability of its slot would seem a more likely nasty at boot than paste to me. Cache cards use a piddling amount of power as compared to an accelerator and haven't got the intelligence to shut themselves down. Forgot to mention that my Cache DIMM appear to function fine where the Sonnets don't.
