Nubus Video Card Info
I think this is probably basically the same thing as a Pickles 24(A?). See this image here:
index.php
from the image gallery Mr. Shinbayashi sent us. You have the same five rectangular BUG-branded chips with a part number beginning 1412F; you have the same big BUG chip with part number HG63F... and you have the same RAMDAC. On this card you do not have the unpopulated slots on the 24AW, and the characteristic four DIP switches have been moved so they can be accessed from outside the case (they set various parameters for the monitor).
Can you dump the ROM please?
index.php
I think I have the 8-24A... If it is at all pertinent.
macuserman
index.php
I can see the similarities, I wonder why they rescrambled the entire board layout though? Also not sure about the Delfi branding, I get a big splash screen with the Delfi logo when it powers up.
What's the easiest way to dump the ROM? Do I need to pull it off the board and put it in a programmer or is there some sort of other method?
Given that the ROM is socketed I'd probably just pull it out and read it in a programmer personally. I can't remember the incantation to read it on a Mac that it's plugged into but one does exist IIRC.
macuserman
It is a 3MB video card. Each chip is 128kByte.
Is that good? I’m used to the newer cards not the older stuff so I have no idea where that puts this card in the lineup.
Ok let me see what I can do.
It is the standard "as much as you could ever need" amount for old cards. It is just enough to do 24bit colour at 1152*870 - that is the two page display / 21" resolution. 24bit at that resolution in a NuBus machine is crazy high end.
macuserman
Nice! So very good card then, for its intended target anyways.
t-shinb
New member
I'm Shinbayashi, the developer of Pickles cards. I'm sorry I didn't notice this post. Defi24 is an OEM product of Pickles24A+, and the internal structure is almost the same. The switch on the panel is for selecting the monitor resolution, but no documentation is available. The maximum resolution is 1024*768/75Hz. Maybe acceleration will work with CDEV-S/W for PicklesCard.
I have attached a photo and catalog of Pickles24A+.
I wish you good luck.
  • 06_Pickles24A+cat1994.pdf
macuserman
Hey thank you! That is super helpful! I'll definitely give that a try!
obsolete
@t-shinb Thank you very much Shinbayashi-san for joining and sharing this information about Pickles! If you wouldn't mind, could you please tell us the story of why it is named Pickles? I like the name and wonder where it came from.
t-shinb
New member
I am also very happy to be able to contact old users of Pickles products. I don't remember the exact origin of Pickles, but I think Pickles is a well-known preserved food. I think the name came from that our planning manager who loves picnics and wants to eat pickles on a picnic. The very first catalog included both PICNIC and Pickles.
olePigeon
@t-shinb Over here in the United States, "pickles" usually refers to dill pickled cucumbers. It's very popular to have on a sandwich or as a side dish to eat on its own. They can be all sorts of flavors from dill, sour, salty, spicy, or sweet. Dill and sweet are the two most popular pickles in the United States. If it isn't a cucumber, then we'll usually call something "pickled," such as "pickled onions."
There are a few exceptions such as sauerkraut. For some reason we still call it sauerkraut, and not "pickled cabbage." I think maybe because even though it's German, it still sounds the way it tastes. So no translation needed. It's sour. And it's cabbage. Sauerkraut. :)
