jholt5638: Will switching to nubus scsi controller give any boost over the onboard one?
In my experience, the advantage of a NuBus SCSI card is firstly to give access to the very (well, relatively very) new SCA drives that are very large, quiet, fast and hot. As has often been discussed in these fora, many SCA drives will not work on an 8-bit SCSI bus. All Mac internal SCSI-buses are 8-bit. LVD-SCSI is 16-bit and it would almost usually allow the use of 146GB SCA drives. Such a drive is useful in Quadras and above, which can run Mac OS 8.1. Your Q700 mightn't be able to read a 127GB volume quickly, but with 8.1 it *will* be able to do it.
The second advantage is speed. With the newer drives with their larger caches and faster spin times, 8-bit SCSI can access only so much data per second. 16-bit SCSI can access much more. Whether that is useful or not is another matter.
As a matter of reference, I ran Speedometer 4.02 on my IIfx. The rating for disk for the 50-pin HD in there at the time was 1.3 while the equivalent rating for a SCA-drive with 80-pin-to-68-pin adapter connected to a NuBus FWB JackHammer was 2.8
