Hey there Paul!
Welcome to the club !
I can at least answer some of your questions, but also take solutions of others into consideration as there are so many people here with way more experience than myself.
1.
The batteries are a bit of a difficulty, there are a few options with these:
*The older soldered ones tend to keep charge for a very long time, and are not really prone to leaking/exploding, so you can just leave them in.
*The safer option however is to just remove de-solder them, or clip the leads and just remove them.
*Third option would be soldering a battery holder to the board so it can be easily swapped out.
(I just clipped mine to be sure, and I myself don't mind setting the clock when it's been unplugged.)
2.
Caps!caps!caps!
The caps most talked about here are the logic board caps. The SE models have the older style axial caps that do not tend to leak or give much trouble.
Much worse are the SMT-style aluminium can capacitors on the newer board.
I would NOT recap your style of caps, I WOULD however cap the newer style caps in newer Macintoshes.
The caps on the analog board may also need recapping in the near future, however if you have no serious (video-)trouble and see no serious leakage, I would leave them alone for now.
The rest, I can not really help you with.
Good luck!
1.
2.
Caps!caps!caps!
Good luck!
