Moving Caps-n-Coils - Electrical Complications?
Trash80toHP_Mini
NIGHT STALKER
Is there any electrical reason this Tank Farm and Coil couldn't be relocated an inch or two to the right?
I'm thinking caps with heat shrunk wire leads and a wired extension for the coil with everything hot glued to a carrier board ought to be OK.
What say? :?:
James1095
The thing you will want to watch for is parasitic inductance and resistance in the leads. That looks like a switchmode regulator which can have very high peak currents at high frequencies. Notice the parts are clustered tightly together connected by big fat traces. You can *probably* get away with moving things around a bit, but make sure you use heavy enough wires and keep them as short and direct as possible.
Are you trying to make room for a longer hard drive? You might see if you can find tantalum or ceramic capacitors that are low profile enough to fit under it without moving them.
Trash80toHP_Mini
NIGHT STALKER
THX, yep, I figured that tank farm and coil are the ElectroCrud for conditioning/converting the battery's power input, I'll either not be using a removable battery at all or using a different form factor battery mounted 90 degrees counterclockwise from that connector. That depends only upon electrical compatibility of the replacement battery and the successful lopping off of about 1/2" to 3/4" of the, all but empty, PCB peninsula where the FDD connector is right smack dab in the way. [:O] ]'>
HDD was a good guess! :approve: Make that a CD-ROM drive poking out the left side and you'd be right on the money! [}:)] ]'>
Trash80toHP_Mini
NIGHT STALKER
Where is Waldo? The 1400 boots and runs TechToolPro from the CD just fine, but some parts are conspicuously out of place. }:)
KlugeBook-ONE.00.jpgTank Farm and Coil relocation hack testing comes next! }:)
