Mother Board upgraded on Mystic Color Classic to run at Native Screen Resoluition . Can I still upgrade the Analog board for 640X480
djayhawk2020
New member
Bought a Mystic CC but the Mother Board was upgraded on Mystic Color Classic to run at Native Screen Resolution. This was done by changing an escalator chip on the mother board. Can I still upgrade the Analog board for 640X480? Or do I need to UNDO the motherboard hack and then upgrade the Analog board?
Byrd
Welcome @djayhawk2020
See here for more info:
If your LC575 board runs @ 512 x 384 resolution, if running System 7.1 you might have a patched version of software (unlikely just this), and the "resistor move" mod is highly likely.
If running System 7.5 and above, you will definitely have the "resistor move" mod carried out; which will need to be reverted back to stock for an eventual 640 x 480 mod.
Once reverted back to stock, you can focus on the 640 x 480 mod; I recommend the "VGA mod" for simplicity and I've two CCs (Mystic and Tacky, recapped entirely) which work well with this mod, it can also be reversed relatively easily.
JB
