more Mac-like *nix
ChristTrekker
If you have any tips for making your *nix desktop more "Mac-like", please post them in this thread! E.g., which desktop, what theme, settings, etc. Screenshots to match the description would be great.
Osgeld
Banned
what are you using is going to make a difference, IE ubuntu 10 out of the box with gnome is pretty mac-like-ish out of the box, add a dock application, re-arrange a tool bar and its pretty durn close in terms of layout and look
something else like KDE or fluxbox its going to be a whole different set of things to do
ChristTrekker
That's kind of the point of this thread. Using $foo window manager, and $bar theme, and adjusting the prefs/widgets like $so, it is kind of like a Mac.
I just set up Xubuntu (Ubuntu Linux with Xfce desktop) with its Platinum theme, which puts the window widgets in the correct locations for you. In the Appearance control I set the desktop to use a light theme with a similar shade of gray - since classic Mac OS didn't have a task bar sort of deal, that's the best I could do. I have the Virtue font installed, so I use that for the window manager (title bar) and theme (menus) font. By default it's focus/raise-on-click. Not too bad, from an appearance standpoint.
