iamtheSpicer
New member
Hello, I posted on this forum before about my Powermac G3 all in one machine rescued from a scrapper a year and a half ago. I found that the machine would constantly restart and make crackling noises from the CRT, so I was initially disappointed, but later I disassembled it and did some soldering touch ups to cracked solder joints on a major internal power connector. The soldering did help, and especially after letting the machine sit for a while without use, it seems to be 99% stable in regards to the CRT and not having sudden restarts. I only mention this issue because of the small possibility that it may bear relevance to the actual topic of this post.
My current issue with this machine revolves around my attempt to install a SATA SSD into it. I bought two 120 GB Micron SATA SSDs from a scrapper that seemed to be fine on Gparted and tried both of them in the Molar Mac (not at the same time). I used the original IDE cable and a JMicron IDE to SATA bridge to connect it. Both drives initially installed Mac OS 9.2.2 without issue and the drives could be initialized without issue. However, after a couple of boots, or sonetimes the first boot, the installations failed. Sometimes they would boot with extensions off, other times not, and sometimes they would lock up in the Finder. The worst issue was when having an SSD plugged caused a blank screen and not being able to boot, even from a CD. I went through some trial and errror and found that the RAM, CD drive, and floppy drive were not causing this, and that it probably rested on the SSD, the adapter, the cabling, or a combination. I would like to ask what possible solutions would be available while still being able to use a 120 GB SATA SSD. I have heard that my issues could be the cable, and that a new 80 conductor IDE cable could be more reliable. I could also try to use a PCI IDE card that may prove more willing to accept the drive than the onboard controller. Lastly, the bomb error codes that I encountered on startup that may be of help were a bus error, illegal instruction error, and address error code 10. Any help would be greatly appreciated!
