JDW
I have a functional Xceed grayscale adapter that looks exactly like joethezombie's photo. There are 4 electrolytic radial capacitors that are old enough to warrant replacing, especially so since they are only temperature rated up to 85°C:
C4: 10uF, 16V
C5: 47uF, 10V
C8: 100uF, 16V
C9: 100uF, 63V
There are numerous 10,000-hour 105°C rated replacements available on Mouser. Have any of you grayscale adapter owners performed a recap on your adapter? And more specifically, do any of you understand the function of the adapter well enough to know if replacement caps with significantly lower ESR (than the stock caps) would actually create problems?
Thanks.
C4: 10uF, 16V
C5: 47uF, 10V
C8: 100uF, 16V
C9: 100uF, 63V
Thanks.
