Dennis Nedry
I have purchased from Narion and successfully rebuilt a Mac TV using spare LC 520 parts. The machine successfully starts up and looks totally awesome (pictures to come).
I had a little issue with the screws when putting the case together: the plastic on the rear case that holds the screw head had popped off for each screw and was missing! So I just used some washers and longer screws and we're back in business. It does not look bad at all.
I don't know what software to use the tuner card with, though. I tried copying the Video Startup extension that comes with System 7.5.3 into the 7.5 System folder, restarting, and running Apple Video Player but that didn't work. Any ideas on that one?
