Macintosh SE/30 replacement kit
mc9625
Do you know where I can find a capacitors kit (I mean every capacitors for the SE/30 all at once)?
Is this a good shopping list (from another thread here, not sure if is the "definitive" list)? :
10x 47µF (16V) - C1, C3, C4, C5, C7, C8, C9, C10, C12, C13
1x 1µF (50V) - C6
Replace with Axial Electrolytic:
1x 220µF (16V) - C11
1x 470µF (16V) - C2
I will go for recapping with a friend of mine (I have all thumbs - I guess you say so - but he has good soldering skill).
And I would like to find a replacement for the battery too. Which is the right model for the SE/30? And any good place for online shop (with international shipping... I live in Italy!)
Thanks (and wish me good luck!)
bibilit
Yes your are good to go, probably any Electronic shop will be able to supply those, even in Italy.
The battery is 1/2 AA 3,6 Volts (probably a little tricky to find, but if you have not right away, won't miss it) you don't need a battery to start the SE/30.
Elfen
Last I checked Element 14 sells caps. It's known as Newark in the USA but as Element 14 in the UK and Europe. I'm usually buying hard to find Raspberry Pi stuff from them.
SE30_Neal
The battery they sell in maplin in the uk for £4.50 i just walked in and there it was in the battery section, no ordering.
Paralel
I just leave batteries out unless they're necessary for the machine to work. I'm retarded and would forget they're in there and the battery would just detonate eventually.
Paralel
My point was unless you see it at certain intervals, good luck remembering in 5-10 years.
