mousehouse
Hi all,
I've removed the battery from my newly acquired SE/30 which (thankfully!) has not leaked. Now I'm looking to replace the battery with a good one that will last another 10-20 years without leaking.
Searching for the part number P/N 742-0011 on eBay gives a few results in the $50 range.
It appears to be an ER14250 battery. However, the versions I find for a few $ are typically non-rechargeable.
Any recommendations for a working replacement battery?
Thx
Thx
