Macintosh SE/30 baterry Bombed - Vertical Lines after recap
Hello everyone
I recently purchased a Macintosh SE/30 with the battery exploded.
After cleaning the area, and recap, I find that the computer turns on fine (correct sound, mouse cursor and floppy disk appear on the screen).
But it has a flaw in the image, some very fine vertical lines.
I have tried changing to reset the RAM and ROM, as well as trying different RAM configurations with the units that the computer had.
Any clue where the problem might be?
Thanks!
Foto de Carlos.jpg20230528_123001.jpg20230528_122855.jpg20230528_123025.jpg20230528_123007 (1).jpg
croissantking
Wow, you’re lucky. Most battery bombed boards need a lot of bodge wires to get going again.
I would suspect the chips at UD8 or UE8 to be the culprit. Probably one of the pins not making contact to the pad.
There is a capacitor that leaks next to these chips and often causes the problem you’re seeing.
You are right croissantking
Finally i found the problem folowing your recomendations.
I solder a cable between leg 14 from UE8 to Leg 23 to UC6 (41264) following the schematics, there has to be connection, but it didn´t.
After solder a cable, the jailbars lines disappear.
Thank you so much!
falen6
I have had this same problem many times and each time it was a broken trace. pad coming for UD8 , UE8...... metered them out , found the break , jumped it and it worked
Let's see if someone can help me find what could be causing the time not to advance in the system.
I have replaced the battery with a cr2032 cell, replaced the crystal with a new one and the two missing diodes D1 and D2 with 1N914 diodes. I'm not sure if the way I've placed them is correct.
Settings like mouse, date are saved between rebots/power offs, but time is not advanced.
Thank you!
3lectr1cPPC
Have you tested continuity for all of those vias near the explosion? One in the bottom left corner in particular isn't looking too good.
Clock is running again, the path that connects to the D2 anode was cut. The clock starts working again, but what I notice is that time passes slower than it should. I have checked and the crystal that I have put is 32.768Khz. Why could this be happening?
I've checked and the clock is not running when the computer is off, but the configuration and date/time is saved. I've also checked all the conection between rtc, crystal Y1, and UK12. And there is conection.
Any idea why the seconds go slowly, and not increaaing when the system is off?
Thanks!
Yes the Battery CR2032 is in the right way. I installed a CR2032 Coin Cell Battery Holder with a switch on/off
If I turn off the baterry when the computer is off, all settings that baterry save, are deleted when the computer start
