Macintosh Portable error code
bibilit
After repairing a screen cable (see other post) and recapping the logic board, i tried to boot another Portable.
With a good battery, the Portable chimes endlessly, using the reset switch i have got an error code and the Sad Mac.
03001500
00001FFA
Any idea ?
bibilit
Thanks for replying TechKnight.
Is there any way to discover the bad one (piggybacking maybe) and are those ram still available (pseudo static RAM if i remember clearly) ?
techknight
Not entirely. it isnt easy at all, and its very painstaking swapping one chip out at a time.
However....
Sometimes the traces get broken going to the RAM ICs, so i would grab a magnifier and check all the connections going to the RAM. I will dig up the schematics and post the sheet on the RAM section which may help.
if an IC itself is bad, only fix is to swap them one at a time until you find them, or replace them all.... it sucks. Been there, done that.
flecom
have you recapped it? my portable was giving me similar issues and sad macs until I recapped it
aplmak
I had a RAM issue on one board.. check legs particularly where there was leaky caps... they sometimes ruin the traces there... make sure you rinse and clean the ram with 90% alcohol and a toothbrush to get all the electrolytic goo out from under the chips.. give it a wash in the tub and a scrub with the toothbrush and the 90% rubbing alcohol... then dry well with a hairdryer..
bibilit
SOLVED
Thanks to TechKnight for pointing at the right direction, and with the help of the schematics he supplied to me, i spent a whole morning checking continuity... until almost the last chip, where i lost continuity on one of the legs.
Removed the chip, and
a broken trace !
removed the last chip also, cleaned the area, put them back again and soldered a bridge where the trace was gone.
Not my better job, but anyway, put all back together
Up and running again.
