jmacz
@ExplorerZ a couple thoughts.
I know there was an earlier discussion on the ROM select jumper. Your latest picture doesn't have a jumper installed, and I don't see a ROM installed either. Maybe you had it off for the picture? Not sure, but again to clarify, the W1 Rom Select jumper must have a jumper on it if you're going to leave the ROM slot empty. So to use the motherboard soldered ROM, you need to have a jumper on W1. If you want to use your own ROM chip in the ROM slot, then you remove the jumper. If you already know this then please ignore. But just clarifying. I also am not sure I fully understand what broke on the jumper last time (was it the actual pins on the motherboard or the jumper itself?) but if that area is damaged, you may want to take another look because that might result in no activity on startup.
The area around the BT ramdac (where some capacity work was done) looks a bit wonky - I assume the leads aren't touching anything they shouldn't be?
Also the sound chips (UB2 and UB3) play a role in startup. The legs on UB3 seem a little wonky. Might want to double check those that they are fully connected and all of those pins buzz out properly to where they should go.
I can't tell if it's just the picture, but the chips in the startup circuit (UD13 in particular but also UE13 and possibly UB13) don't look very healthy? Might also want to check all those legs are connected and there are no broken traces there. Note on one of my IIci boards, I actually ended up having to replace all three of them as they were totally destroyed by the leaking C10, C11, C12, C13 capacitors.
