ironborn65
Hi all,
I hope you all in good health, lockdown brings me in the basement often then usual
My challenge is about networking my Macintosh II.
I have:
1)
8mb RAM
system 7.5.5
scsi2sd (irrelevant)
Daynaport (st) E/II card
2)
Installed Apple network software 1.5.1
Installed Daynaport driver 7.7.1 , specifically for (st) E/II
3)
hardware diagnostic identifies the card correctly, no errors found
software diagnostic identifies correctly the drivers
3)
appletalk enabled with control panel chooser
control panel network set to Ethernet
macTCP shows me the ethernet address
macTCP set to 10.0.0.5 (I have hurdles to set class B or C but it does not matter with this topology)
connected using RJ45 to a stupid hub where a ubunbu laptop is also connected
4)
the green led at the top of the card flashes only if the cable is connected
apparently there aren't the usual yellow/green leds close to the RJ45
the cable has been tested
BUT
the led in the hub never turns on, this is the most frustrating issue
the ping to the ubunbu never works
Can someone provide an input, an idea to work out?
Shall I assume the NIC is broken?
thanks so much
all the best
Pierfranco
I have:
1)
8mb RAM
system 7.5.5
2)
3)
3)
4)
BUT
thanks so much
all the best
Pierfranco
