blindowl
I'm trying to get this Novel Etherport II card working with a IIci but without any luck. I've paired it with a CentreCOM 201TS transceiver, connected to the network with a CAT6 cable.
I've downloaded the drivers from https://www.vintageapple.org/macdrivers/network.shtml. Tried clean installs of different systems from 7.1 to 7.6. Both MacTCP and OT+TCP/IP. DHCP doesn't work and manually assigning an IP address doesn't work.
TattleTech identifies the NuBus card correctly and the Link light on the transceiver is solid green.
I've found a few other threads mentioning this card as problematic. Someone wrote the coax port is more reliable, but I don't own any coax/RJ45 adapter.
Anyone else has an Etherport II card working?
Also, there is a switch on the card, "ENET" or "CNET", what does it do? Switching between coax/AUI ports?
Thanks!
Thanks!
