Snial
Hi folks,
I have an Apple Ethernet PDS card: "Ethernet LC Twisted Pair Card: ASSY 820-0532-B". The LCII (really a Performa 400) has System 7.1 + Extensions: Apple Ethernet LC (10 Base T socket); EtherTalk Prep; EtherTalk Phase 2; Network Extension all installed. I have MacTCP and Network control panels installed. AppleTalk is enabled. I thought the first step in getting our iMac G4/1GHz to talk to the LC would be to switch AppleTalk to EtherTalk (does anything work if I don't?). I did a PRAM reset, but when I tried to use the Network control panel I got:
"Could not switch to Ethertalk due to an error. Your connection will be reset to LocalTalk."
Do I actually need EtherTalk to do this stuff, or will MacTCP just simply use the Ethernet card? The Green LED comes on. I've now tried connected from my iMac G4 on en0 (which is Ethernet), using ping -I en0 192.168.0.50 (MacTCP says that's its address). I've tried to Run Eudora to get MacTCP to start up, so that Ping might be supported as per this thread:
68kmla.org
It'd be nice to use the Ethernet card as it would make transfers easier than using a Zip drive, I could go from LC to iMac G4 to USB then, assuming I can find a simple way to do ftp without ssh.
LC Ethernet Not Working 7.5.5
I'm trying to bring my old LC back online after replacing a failed hard drive. Back in the day, it was a web server and I had it serving up a tutorial on how to make your own old mac web server. Since installing the new HDD, I've upgraded the OS to 7.5.5 again (drive came with 7.5.3...
