Macdrone
So I figured even tho I have had it for months that I would put it here. It just never dawned on me it may be special. From what I can tell both my 128's (that are actually 512's) have last revision C motherboards.
According to http://www.folklore.org/StoryView.py?project=Macintosh&story=Macintosh_Prototypes.txt
I will link all the photos I have taken of it here.
Couple of questions tho,
1) Are all the 128's and 512's have a hole big enought to put the twiggy in? I ask because I have not seen inside close enough of others than the ones I have.
2) Think the shielding was not addd to see the heat build up on plastic? I compared the 2 and they have residue in th same places but you cannot see it, only feel it on the shielded version.
3) The inside is as yellow as the outside, should I retrobrite or leave it alone?
4) The front off the other Mac analog board says 1986 so I am sure it was a 512 to begin with but its asset tag is M0001 serial F4423MSM001, so maybe just pieced together to keep it working?
I am pretty stoked now. Guess I got my Grail wether its real or not I will hit my "I believe" button anyway.
I hope you all enjoy me sharing it. If your ever up the Portland way let me know and we can get together. I love trading stories and parts.
