I got this error 00000003 00040000 By looking at Troubleshooting_Your_Macintosh_1992 : The RAM test failed while testing bank B, after passing the chunk tested for code $0002. The Z field indicates which bits failed as in code $0002.
Also the second line shows what bits may have failed. But not sure how read 00040000 and what clue it makes.
I was initially running 4x256kb of RAM I am sure works. Also tried to eliminate bank B by switching the resistor from 35 to 36 and using 2x1MB.
Still the same issue.
