I searched and found a thread about cleaning up the 'regular use' dirt off of a compact mac, but my problem is a little yuckier. At some point in my Mac's life, some stuck (I'm guessing) a couple of those 'paper holder' things on both sides of the case. The only remnant of this outrage are four yellow rectangles of what remains of the adhesive. The stuff is super dry, and super bonded to the case. Short of sanding it off, I'm out of ideas for how to get rid of it.
I tried leaving a very wet washcloth on it for an extended period of time to see if that would 'rehydrate' the adhesive. no go.
I tried putting copious amounts of alcohol on it to see if that'd work. No go.
I tried bulk quantities of 'Goo Gone' to see if that'd have any effect, but had no love.
Has anyone encountered this and discovered a good solution for getting rid of it?
