[SIZE=medium]Hi, Recently I got an Mac SE/30 that was not working. When turning on the Mac the sound is Ok and the hardrive is spinning but no video. The screen is black. A RasterOps graphic card was installed ( RasterOps 264/SE30) when I got it. When I attach an external monitor to RasterOps its working perfect. Color and everything is perfect. [/SIZE]
[SIZE=medium]Without the videobard installed the screen is black. No difference if the board is installed or not, the screen on the SE/30 is black.[/SIZE]
[SIZE=medium]I noticed on the logic board that it is a wire [/SIZE][SIZE=10.5pt]between UE7 pin 6 and UI6 pin 3. The trace between pin 6 on UC7 and pin 33 on the GLU CHIP has been cut. [/SIZE]
[SIZE=10.5pt]. [/SIZE]
[SIZE=10.5pt]I have seen in previous threads https://68kmla.org/forums/index.php?/topic/21888-se30-rework-wire-and-bomarc-vs-apple-schematics/?hl=reworked&do=findComment&comment=225691https://68kmla.org/bb/index.php?/to...eworked&do=findComment&comment=225691 that it is related to the NUBUS card. Is this wire because of the graphic card? Hove to get the SE/30 to work without the RasterOps card?[/SIZE]
[SIZE=10.5pt]The logic board is not recapped and it could be UE8 that’s bad, (https://68kmla.org/forums/index.php?/topic/23819-typical-video-board-issue-with-all-mac-se-versions-and-se30/https://68kmla.org/bb/index.php?/to...oard-issue-with-all-mac-se-versions-and-se30/ ) but would it be working then with the RasterOps card??[/SIZE]
[SIZE=10.5pt]The Logic board is marked 820-0260-10, 630-4198-[/SIZE]
[SIZE=10.5pt]I would be grateful for any help.[/SIZE]
